Old 01-19-2018, 02:43 PM
Tjd Tjd is offline
Here’s pictures to compare original CSX 4000 wheel to the quick release hub.
The wheel on the quick release is one that I had left over from several hundred steering wheels I made for Shelby when I was there.
I’ll find out next week what serial numbers of which 4000 7000 this hub and upper shaft will fit. Hub and shaft and hardware to changeover a CSX car. $600.00 if you need the outer steering tube additional
$125.00
Conversion is simple unbolt
u-joint at upper steering shaft pull it out and put new one in mount steering wheel to new hub.
Tom
Cannot load pictures at this time will try later
