Old 01-19-2018, 05:05 PM
spdbrake spdbrake is offline
I'm assuming you have contact cement adhesive that needs removal.
We switched to the 3M citrus based solvent for wing boot glue removal etc a few years ago with good results.
Should be safe on your paint but as Strictly mentioned check it a inconspicuous spot first.
The spec sheet shows its designed for adhesive types removal.
https://multimedia.3m.com/mws/media/...itrus-base.pdf
https://www.amazon.com/3M-6040-ADHES.../dp/B003ZHOZRO
Don't confuse the 6040 remover with the watered down 03618 automotive adhesive remover.
https://www.amazon.com/3M-03618-Adhe.../dp/B000BQYA7W
