Thanks for the advice. The 428 CJ is just a little more aggressive than stock and the vacuum canister has the adjustment screw, I'm going to do some testing to dial it in and use the vacuum timing port off the carburetor if it needs more than it will be direct off the manifold. As a friend told me the most work you want to do on this car is put gas in it.
