Spitfun,
You might try California Car Cover. I got one of theirs, I believe called the Superweave. You may also try Covercraft, the similar one there I believe was the WeatherShield HP.
These can both offer Cobra configurations. You may also try searching this site if not already as there are some threads including that topic I believe. There are certainly other good options and price ranges.
Mine is not as industrial outdoor duty as some may be, nor is it as tightly form shape fitted as some, yet still configured for the Cobra shape. These can be specified for rollbars, mirrors, etc. if I recall properly.
I went with an indoor/outdoor combo that had relatively high feature sets/qualities covering both. It's lightweight, soft, and loose 'enough' fitting to not easily scratch/pull across the paint. It packs relatively small and is (commercial) machine washable. 'Breathability' was something I was looking for to help control moisture/condensation/mildew in case covered for any extended periods. Some of the features I was after.
There are options to tie across under the car to hold better in outdoor environments.
Best of luck. Brent
Reason: Add re: (commercial) and 'Breathability'
