Thread: Finding TDC
Old 05-28-2002, 10:12 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
man that's a lot of initial timing.. but if it isn't pinging.. what is the compression ratio? I cannot get that much and I am about 10:1 or just over that.. maybe 10.3.. and I get it kicking back at 15-16.. and then it pings at mid throttle under load.
A good "dial indicator" is a 1/4 inch wooden dowl carefully inserted into the chamber and cranked by hand to determine TDC. I said five degrees as an example. Within a few degrees plus or minus might have been a better example.. Zero is ideal, but it almost never happens that way.
Regards,
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
