Originally Posted by Grubby
Buzz,
You can swap gears, but you will need to follow the full book process to shim everything. It is a big job. It takes me about 8 hours to set one up, but I don't do it everyday.
What is the benefit of swapping to a series II? If not big benefit I would save the head ache and stay with the Series I with the 3.54s.
Don't Series Is have ball bearings in the stub shafts and Series IIs have tapper rollers?
John
I thought the series 2 is supposed to be better because of the tapered roller bearings in the outputs being less prone to failure. My old series 1 has a lot of miles on it and its easier to find brake parts, etc. on line for the newer axle. I guess its all moot now that I'm faced with tearing the diff down now if not for the fact that I have a bunch of new parts already in transit for the series 2.
Tropical Buzz
