  #21 (permalink)
Old 02-07-2018, 05:22 AM
joyridin''s Avatar
joyridin' joyridin' is offline
I have had the Team CJ bushings in my car for maybe 8 years now? They work great. Just be warned you may have to touch them up a bit as the Jag dimensions vary a bit from one rear assembly to another. If you have ever taken apart the factory fiasco, these are a dream.
If your set-up has the tapered bearings, replace them also. The last I had heard, the roller bearings were not available, but they rarely wear out. You can replace the roller bearing set-up with a tapered bearing if you have the tapered housings with the correct brake caliper mounting.
