Very helpful! Thank you. I think I'm going to experiment with this using a couple mounted spare tires I have. As for the lettering, too bad there isn't a way for these to be pre-spaced in a way that makes it easier to install. Like some sort of backing that dissolves or scrubs away after installation.
Perhaps one could lay out the lettering as you did and in addition to the chalk lines use large pieces of tape or adhesive vinyl to "pick up" the dry spaced lettering in larger sections?
