Originally Posted by spdbrake
When you had the sender out and were checking travel, did you try it connected to the gage? Alligator clip a local ground and run it thru the swing and watch
Yes. With the sender out of the tank, I jumpered it to ground and to the signal wire. As I moved the float, the fuel gauge needle moved. I thought I had it solved, but when I put the sender back in the tank, reinstalled the tank, and poured 5 gallons in the tank, the gauge did not move off of dead empty.
I'll read the article. Thanks for your help.
