Just a quick note I discovered today. The part number in the photo with the boot actually coincides with a bellows that has one straight edge. Part number C2AZ-7277-A is the one with a round bottom.
Blas-
Good points about the 4 screws for the shifter ring. I updated my base with some Home Depot clip on speed nuts when I noticed two of those shifter ring screws were already loose and backed out because they had only caught the edge of the fiberglass cut out hole for the shifter.
Jim- I probably ordered a boot from the same e-bay seller you did today. Let’s hope they do the trick.
"Some things just get meaner as they get older"
.....Gumball Rally :-)
