Is there a lock nut below it? If so, it may be binding the lower half. Screw the top of the handle back on and then hold it while you put an open end wrench on the lock nut and loosen it. Are those two holes facing up? If so, then any set scores would be for connecting the lower half of the handle to the upper half.
Jim
