Unfortunately we can’t run floor mounted as there’s no room for your left foot when cruising. I’m trying to run underfloor exhaust so space fir the downpipe takes a huge chunk out. If you think your footwells are tight, you should try RHD! It’s an inch narrower before you start.
Thanks for your input, but I mocked up the pendant system today at it will be okay, just. The 3 m cyl s are above the pedals and the reservoirs will be on the glovebox, out of sight, away from the worst heat.
However I believe you when you say you’ve had no fluid boiling problems. Could simply be a little knowledge is a dangerous thing, esp on forums.
