Thread: Headlight woes
Old 05-29-2002, 12:42 PM
flipper35's Avatar
flipper35 flipper35 is offline
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Default Headlight woes
I was working on my high/low beams and can't figure something out. On high everything looks good but on low the lights get very dim and the high beam indicator is dim but on. If I check the wiring, what appears to be the high beam stays hot on high or low beam. If I disconnect what appears to be the low beam and I switch from high to low, the lights don't change whereas I thought they would go out (the high beam indicator does go out). Do I have a funky relay or did I screw up in the wiring.
This wasn't an issue until I used the extra bright halogens as I never switched from high to low beams before.
Brent Dolphin
