Old 02-27-2018, 11:20 PM
pormgb pormgb is offline
Banned
Cobra Make, Engine: Rowan Replicars, 352 4V
I fabricated a mounting system for my Rowan Replicars replica, the car came with an 8" Ford rear end and leaf springs.
I mounted the differential on a cross member that bolts to each side of the upper frame rail, I then used a series of heim rods to hold the differential in place and gave me some adjustment. I added brackets to the cross member that provide the shock mounts.
I also used a 1/4" plate on the bottom of the differential, heim rods connect that plate to the chassis at the front and rear. I also modified the leaf spring mount to have the correct angle for the control arms (level with the lower control arm diff pivot points).
This mod was quite a job, I had to pay special attention to pinion angle and the height of the differential so the drive shaft would have the correct angle.
Rowan Replicars 1965 Cobra Replica
352 4V, T5, Jaguar Posi rear end with 3.30 gears.
https://www.facebook.com/pormgb/
