  #27 (permalink)
Old 03-02-2018, 05:07 PM
legenmetals's Avatar
legenmetals legenmetals is offline
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
I did some reading on your issue and it appears that it is common for the splines to rust up. Pushing the axle out with about 5 ton of pressure seems to work. That seems like a lot of pressure. I also read that they Loctite the splines. I'm not sure if that is standard procedure or a mechanics better Idea.
If you try to press again ( I would ) protect those threads.
