Thread: Dim Headlights
Old 03-03-2018, 06:18 PM
Pasta Power Pasta Power is offline
Cobra Make, Engine: CRI
Default Dim Headlights
I have been reading a thread with people having dim headlights and the high beam indicator staying on dimly without the high beams on. I have a CR I and I'm very slowly working out the kinks in it. Does anyone know if the problem is with the gauge of wire going to headlight, or should I get halogen bulbs, or is the light not wired correctly. I measured the voltage at the connector and I'm only getting 10.5 volts on low, and 9.9 volts when I switch to high beam.
Any thoughts or help would be greatly appreciated.
Thanks, Mike
Pinckney, MI
