Disconnect the line from the caliper and see if the pedal pushes fluid through the flexible line ok..
That way you know if the problem is before the caliper or not and also the telltale if then the pistons will push back into the caliper as well.
I just had to replace a flexible line to the caliper that had blocked internally due age on my Mustang.
