Thread: Dim Headlights
Old 03-05-2018, 06:29 PM
studebaker53 studebaker53 is offline
Pasta Power,
The bad parking of the wipers...just get used to them not a big deal. If the wipers are slow, the cables MUST be in a conduit tubing and not kinked at all. The wipers could be slow because the lubricant in the tubing and cable is drying up or had none to begin with. It is a bastard of a job unless you pull the dash but sounds like a lube job should help. Also that wiper motor draws a lot of current so a good ground on that too.
