Hi all i like every one here was looking for a quick fix, but the more you look into it the more intricate it is, Treeve is on the right path the ABS from a donor car does not work for us its not like you can find a donor car with similar overall weight, front/rear weight distribution, centre of gravity, roll rate, and wheelbase.reprogram the EBCM (it cost manufacturers millions to develop test and implement then TO WARRANTY all the parts etc here is an old magazine HOW TO:
ABS For Hot Rods - Installing A Late-Model Electronic Stability Control System - Hot Rod Network read the whole story and you will come up with the same thing as Treeve has been saying, and what he says "They have decided to impose this piece of policy based on their misunderstandings" and the best Quite "small minded bureaucrats" they don't understand what they have.(or do they?) Read the article see if it becomes clear to you as well.
