  #260 (permalink)
Old 03-07-2018, 05:19 PM
Mongoose930's Avatar
Mongoose930 Mongoose930 is offline
Cobra Make, Engine: Hi-Tech
Originally Posted by Mongoose930 View Post
Hi Steve,
Craig put a lot of time and thought into getting the cap exactly where we wanted it. First, he drilled the correct pattern into the body. He then added the appropriate spacers and gaskets and screwed the cap to the base and tightened the cap. Since the base had no holes drilled in it, Craig was able to locate and clock the cap assembly exactly where we wanted it and then drill the six holes into the base and mount it. I think it came out great!!
I got the process backwards...
Craig tightens the cap to the base with the appropriate spacers and gaskets, drills the base with the appropriate pattern and then transfers the pattern to the body.
