Originally Posted by djspiderman
I'm running Evans Waterless coolant. Google it. Very good stuff. Has boiling point above 350 degrees. Never have to change it. Expensive but worth it.
Yes. I've been reading about that stuff. You have to flush the system first with the Prep Fluid to remove all the water/coolant in the system.
They say it will not corrode the system like traditional coolants do and it never needs changed. But it is quite expensive, as you've pointed out.
$32.00 a gallon for the Prep
$46.00 a gallon for the coolant.
