I switched the 9" pinto brakes for the Wilwood Dynalite 11" discs. Dropped around 30lbs from each wheel. Better braking for sure. Then I put 11" discs on the rear with a wildwood adjustable proportioning valve. I changed the MC to accommodate the rear discs...need a bigger reservoir for those. I used Classic Performance Products 15/16" bore master. No booster. It works well but I did change the pedal ratio for manual too because it was set up for booster pedal ratio. Pics in my gallery.
