BDR1605,
I can't speak for BDR wiring harneses, but i did use Speedhut gauges for my build. Speedhut was very flexible during the display face layout process and their gauges went in and worked flawlessly from the the first start. The gauges in my Speedhut cobra package were supplied with temp and pressure sending units and sheilded pre-terminated cables. They provide sheilded cables to reduce impact of interference from ignition and other sources. Analog signals are typically transmitted in cable with shielding grounded at one end only.
I would advise that you use the cable supplied with each gauge.
