Thanks again for all of the help and info. I'll pull the stub axles out tomorrow morning and see what bearings I have. With the signs of water and rust inside in the case when I pulled the cover off, I'm really worried about the internals.
Can the internal parts from the Series 1 3:54 case swap into the Series ll 3:31 case? With the cover off and everything flushed out and sprayed with WD40, I can now hear a bit of noise coming from the outputs on both sides when I turn the pinion.
Tropical Buzz
