  #23 (permalink)
Old 03-26-2018, 05:54 AM
joyridin''s Avatar
joyridin' joyridin' is offline
I had a problem with some Wilwood brake rotors a few years ago. They item did not match the print they had online. I called their tech support. She said she would check and get back with me.
Two days later, she calls and says "I went back and looked at the ones on the shelf. They are all that way, so they are correct." I explain again the problem as the actual part does not match the print. She tells me the print is wrong because all the rotors look that way.
I gave up and returned them. Summit had a set on the shelf when I returned them and we compared those. They had been on the shelf for about a year. They matched the print.
