03-27-2018, 05:38 AM
Vic
Originally Posted by Treeve
Having two overdrive gears is a wank... especially when 5th in a 5 speed is not the same as 5th in a 6 speed. The 5th in a T5 is 0.68:1, where’s a T56 normally has a 0.8 5th and a 0.63 6th. So you’re giving up 0.05:1 in ratio in 6th and you’ve got a 5th gear for... wank factor. The difference at your quoted 1850rpm at 110km/hr with a T5 is that you’d be doing a bit less than 2,000 rpm with all the rest of your drivetrain the same. And you’d do the same revs for all other scenarios in 1-4 gears with 5th in the T56 being the standout as not having an equivalent.
Plus the T56 weighs more. A lot more.
Interested to know what you shim to improve the gearchange though - got more than a couple of LS conversions with T56’s attached that I’d love to improve. Link to an article on how to do it?
Treeve
pretty sure, from my calculations, that my 6th is 0.5:1. Aussie Mike built the box, he's the one to ask on technicalities.
Ben in AU
