Hi Paul
I cannot reply on your original question about the mixture screw.
But as you mentioned that it worked perfect before you removed the distributor, to fix an intake leak, I would search on this side again.
It worked before!
Did you replace any gasket or could there be some small dirt in between?
If I would be you I would try to go back with the settings on prior the intake work and check the work you did.
Not saying that you did something wrong.
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
