Old 03-29-2018, 03:34 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by sd427 View Post
You might also find that the internals are the same between gauges of different diameters. Just because a given manufacturer offers gauges with different diameter faces, that doesn’t necessarily mean they designed a whole new set of guts for the larger diameter, they may have reused the same guts as the smaller diameter gauge.
Very true in some cases, but only if the scaling is the same from end to end.
