Old 03-30-2018, 01:23 PM
Jim Coleman's Avatar
Jim Coleman Jim Coleman is offline
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Buzz,
I took the fulcrum brackets off, and the shafts are the same length, so I have another problem somewhere.
Today I mounted the stripped rear end chunk with the top bolts to the frame so I could check the brackets that I welded up the holes and redrilled.
When I tried to slide the bare fulcrum shafts through the brackets and into the Arntz frame noticed they were off a little.
So, I redrilled them again and welded up the ones I repaired and now the fulcrum shafts slide in easily into the Arntz frame. I did have to grind some off the flat side of the mounting points on the brackets on the RH side, and shim up the flats a little on the LH side.
After I get this wishbones installed on the fulcrum shafts and install the shafts into the frame I'll know more about what happening.
At least I will now know that the fulcrum brackets are mounted correctly.
Thanks,
Jim
