  #42 (permalink)
Old 04-06-2018, 05:43 PM
RedHawk's Avatar
RedHawk RedHawk is offline
Originally Posted by cycleguy55 View Post
Cable interference - probably two options:
  1. relocate the cable by fabricating a new bracket; or
  2. provide relief by grinding away a portion of the bellhousing.
I'd go with option 2. Remove the cable and bracket and get in there with a grinder, Dremel tool or file.
As to the return spring - source a proper return spring, then drill a hole in the clutch / shift fork to insert the end of the spring. OTOH, this spring is probably the clutch / shift fork return spring, with another, heavier spring on the clutch pedal or the pulling end of the cable - as seen in this diagram: http://repairguide.autozone.com/znet...528006284c.gif
If that's what your setup looks like, the clutch / shift fork return spring is only doing light duty, so doesn't need to be too strong - it just needs to be better mounted to the fork.
Thanks CycleGuy
So one other things I was hoping you could help me with and what caused me to investigate the clutch cable was the fact that when speed shifting through the gears ( not power shifting) second, third and fourth sometimes can not engage and it litterly causing a grind or just wont engage. If I perform a healthy run but take a slight pause between shifts there is no issue whatsoever.
What I was curious about was whether the cable isn't properly engaging the clutch fork because of the current setup or does this sound like a syncro problem? Anyway to go through process of elimination?
