Originally Posted by MAStuart
Thanks again Dan. Don't know what I was thinking when I said shock mount. So yes I should of said sway bar mount. From what you posted things are starting to make sense.
So I now assume the upper rubber bush on the shock has an inner sleeve. Is this correct?
From what my drawings show it looks like the 3/4 dia part of the pin is 6.375. Also the part of the control arm that this pin goes thru to the outside edges is also 6.375 . So if these parts are the exact length the special washers would just be touching the ends of the control arm. Is this correct or should there be a little clearance there so it is not steel on steel contact?
Looking under a car yesterday, it looks like just enough clearance to not drag.
Dan Case
