Originally Posted by Chicagowil
If you do look at a SC mounted low and in front of the motor, why not use a Holly style throttle body, EFI system and fuel rails on a 4bbl intake and not fight with a blow thru carb? The tuning ability is much better and you still have the "original" look of a carb style system at a glance.
I second the idea of EFI, but a Holley-style TB and elbow are probably going to be higher than a carb and air cleaner. I'd be more inclined to get an elbow that bolts to the carb pad and use a modern, inline style TB. All that plumbing under the hood is going to detract from the 'original' look of a carb anyway - may as well go 'all in' and do it right.
Don't forget to switch to a single-plane manifold if that's not what's on there now.
