Bulldog,
I just had a colonoscopy this morning so that may be the rear end noise...
Just kidding but I did have the colonoscopy, all good.
Noise is almost always from the pinion bearing or lash of the ring and pinion. Metal or not, I'd look at the lash on the pinion and ring then look to replace the bearing regardless. Not that tough to do once you have the pig apart especially what we do to these cars...Are you running a modifier in your 80W diff lube?
