CompClassics, note well taken. I do not see any flapper in the filler neck when looking down from the top. Unless its some sort of ball style that I can’t see. I assume this has to be placed in the vertical position of the neck for it to function properly.
Therefore if I move the return to the capped fitting I should install a flapper in the filler neck. I assume that requires removing the entire filler neck assembly to install one.
BTW your not far from me. Belong to the local cobra club?
Again thanks for the input.
Steve
