Originally Posted by Trubble
Sir,
Your detailed advice worked like a charm! This newbie got her started easily after several slow pumps of the throttle.
Wondering if I ought to just start a"BUILD LOG" covering this and some other issues I have to sort out....
Later.
Bill
Yep, most things on these cars are actually pretty simple. Some of them are
incredibly simple (like an empty float bowl). But, if nobody takes the time to explain them to you, then you have to figure them out on your own, which usually means breaking stuff, or making the problem worse the first couple of times, and then you figure it out.
