Thread: Rear Coil overs
Old 05-09-2018, 12:05 PM
celentanogj celentanogj is offline
Default Rear Coil overs
Can use some help, the rear drivers side is about a 1/4 inch lower than the right,
the CCX was built in 1997, anyone know what coil overs were used? what size spanner wrench can be used? The rims are the 15" Vintage wheels pin drive with the Goodyear Eagle billboard tires, the fronts are fine but getting rubbing in the rear fender wells (left side). I think by leveling the rear will solve the issue.
Also will the alignment need to be done?
Thank you in advance for any help.
