Old 05-09-2018, 12:02 PM
socalliving socalliving is offline
Cobra Make, Engine: BDR 408W
Thanks Morris.
I drilled one 1/8” hole like you did on the cobra cap. Do you really need so many holes? The purpose is to prevent a vacuum, right? My fuel cell and filler tube is is a little different.
I have the capped fitting which is behind the driver side and the other fitting is being used for the 1/2” line which is coming off the Moroso tube and is pointing down. This line(off the filler pipe) enters the passenger backside of tank.
I was going to place a rollover valve on the drivers side fitting.
I post some pictures.
Thanks for the photos.
Steve
