Old 05-10-2018, 01:39 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Keep an eye on tire wear, if the outsides are worn more than the center, you're too low with psi. If the centers are worn more, the pressure is too high. Make sure the front end is aligned properly.
Also, buy a high quality digital tire psi gauge, or the analog needle type with the liquid in the dial (more stable than dry) not some K-Mart blue light special.
Regards,
Kevin
