Old 05-11-2018, 06:01 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by CSX 4133 View Post
What is the maximum cold tire pressure stamped on those Nitto tires? Based on that I would pick a starting pressure (3-4#'s) below it as a baseline.
Then you would be very wrong. The Nitto NT555 G2 tire has a max pressure of 50psi. To put 46 psi as a starting point would be a very bad idea.
Generally speaking, a good starting point is 1 psi per 100 pounds of total vehicle weight.
I was just thinking that tread temps would help you help you dial that in. But maybe that's just a bit OCD.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
