Old 05-11-2018, 05:40 PM
Apex_speed's Avatar
Apex_speed Apex_speed is offline
Cobra Make, Engine: Superformance Mk3 with Roush 427R
Default Fuel Return Line Ideas?
I have an '06 MkIII chassis and am installing EFI. I need to put a bulkhead fitting on the top of the tank for my fuel return.
I have the access panel in the trunk out and found the fuel sender plate the is about 3.5" in diameter. It is not big enough to get a fitting into without rebuilding the entire thing (I could pull it off). It would be every easy to drill into the top of the tank right next to the sending unit but I don't really won't to blow up the car and the garage so that's not an option.
I'm thinking possibly a punch and die setup to make the hole or maybe I'm missing something more obvious.
Thoughts?
Thanks!
