Originally Posted by Mark IV
Pull the sending unit out and put the return fitting in it. The return line can be 1/2 the size of the feed line.
To reduce fuel aeration have the return line with a line going to the bottom of the tank.
That was the original plan and I have the fittings and the tube to get to the bottom of the tank (-6).
It will not fit in the sending unit though. There is simply not enough room without heavily modifying it by moving the sending unit over on the mounting plate, re-soldering mounting tabs, etc, which I can do but that doesn't seem like the right way to do it.
I'm not sure that there is anything smaller than a -6 fitting that would do the job.
