Originally Posted by tamanaco
Nice reading about adjustable camber plate!
Keven, can you tell me more about the JRI double adjustable front shocks? I don't like the feel of the fronts that i have now...think I put in KYB's years back.
JRi front struts are fully double adjustable for compression and rebound. As are the JRi shocks I have in the rear. Only JRi has a strut that will work on our cars. Penske has shocks only and they are inferior to JRi at the moment.
The JRi strut insert will not fit inside the skinny stock strut housing. You will need the race strut housing from BDR. The top of the housing will have to be modified, but once done it looks factory and performs like nothing else.
Do not contact JRi directly. You need to contact JJ Furillo owner of Ultimate Performance (610)790-4071...
Suspension-tuning for High Performance - Ultimate Performance
Tell JJ you have a Backdraft and that Kevin Daigle sent you. He will pull up my file and he will then know the part numbers required to build a setup for you. You can get the race housings from Miami or JJ can get for you from them.
To adjust you just turn little knobs at the top.. You can adjust for whatever driving conditions required. You will want to change to stiffer springs in front and rear, the factory stuff is WAY too soft. How stiff will depend on what you want to do with the car. Please email me here for more info if needed...
