Originally Posted by bingo2
The Street Tee goes into one of the ports on the intake manifold and allows the use of 2 senders/sensors from the same port.
Ah, got it.
That setup doesn't seem to work well. I have had poor luck with them in the past and someone else on here put one on their Roush 427R and also had an issue. The gauge read much lower than actual temperature unless you turned on the heater so the coolant could flow past it and then it read accurately.
Have you tried one on an intake manifold port with good results?
