I'm not familiar with this particular car, but very familiar with composites. How big is the void in both square inches and gap, how many bolts?
Depending on void size, I'm thinking along the lines of injecting an epoxy solid filler into the bolt holes to make an approximately 1" solid pad to redrill and through bolt. You could also do the same in any areas where flex is an issue. Not talking large areas, just injecting in strategic areas to stop the movement.
