Inner Tie Rod End Replacement
Like it says in the tin, I need to replace in inner tie rod ends on my Flaming River rack, which is a surprise after less than 3,000 miles.
Does anyone have any experience removing the inner tie rods from the rack - they appear to just unscrew, any particular tricks?
Also I understand that I will have to cut off the threaded portion of the new inner tie rod (I've sourced them from FR) and weld on the connector from the existing ERA outer tie rod. Any trick to this?
Thanks in advance for any tips or pitfalls to avoid.
Kevin
