Old 05-24-2018, 03:04 PM
LG57 LG57 is offline
Cobra Make, Engine: ERA#134 427 Ctr oiler 2x4's
Listen to Blykins advise. This is an on going question across several engine forums. The steel gear for a steel cam is the correct thing to do. You won't have to worry about metal bits flying around in the engine because there won't be any if the gear is installed to the correct dimension on the distributor shaft.
