Thread: Plug wires
Old 05-29-2018, 04:47 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by TexasSnake View Post
I completely agree with your observation of the MSD plug wire performance. I had been running Accel Pro Stock wires on my FE and didn't think that they required replacement. However, I wanted reroute some of the plug wires and elected to use the MSD universal kit that I could cut to the length I required. After making the change you could actually feel the difference in performance which surprised me. I was curious so I cut two identical pieces of the MSD and Excell Pro Stock and tested them for resistance. Don't recall the exact numbers but the MSD wire resistance was a small fraction of the Accel. Highly recommended if you are upgrading your plug wires.
Must have had some faulty wires.
I've have run the Accel 150 ohm wires, and the MSD wires.
I doubt whether anybody could tell the difference between 50 and 150 ohms, considering normal stock wires are 3k - 8k ohms per foot.
Gary
