Originally Posted by crendonman427sc
Hi Pete,
I will probably have an oil cooler as the car must be period correct, so maybe a small one!?
FIA 6Pin Wheels Agreed!
Heat Shielding is something I had not considered at this stage. I must look into this and decide upon a product. Any suggestions?
Thanks
David
My car has Thermo Tec heat shield installed. ( It is pretty easy to find online) there are a lot of different products out there, and I would assume they all work pretty much the same. I am sure the forum can add some opinions on this. Good luck with the planning and the build.
Best regards,
Byron
