  #26 (permalink)
Old 06-02-2018, 10:56 AM
cycleguy55's Avatar
Originally Posted by xb-60 View Post
Pete - can I ask for your thoughts/comments on the 3.08 ratio with a 4-speed box? I'm using a similar setup for my build.
Glen
There are plenty of online calculators that will give you RPMs at a given speed. You can play with final drive ratios, tire sizes, etc. and quickly figure out what will work for you, how you drive, road speeds, etc. Here's a couple to get you started:
Calculate GEAR, RPM, MPH, TIRE DIAMETER
Engine RPM / Engine Speed Calculator
Brian
