Originally Posted by EM-0785
Kevin,
I at one time had a leak coming from the upper front as well that was hard to find. Ended up that my coil, mounted sideways on the top front driver intake area was leaking oil. Inside the wire receptacle the screw that seals the oil in had come loose. If you're coil is in the same area perhaps that's it and perhaps explain the oil leak and related timing/spark issues?
Best of luck. Brent
Brent,
Good suggestion but there's too much oil on my garage floor for it to be coming from the coil, plus there's no oil on the inlet manifold where the coil is mounted.
Thanks for your input.
Kevin
